Steering Rack - Strip / Adjust / Repair?
13 replies to this topic
#1 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 18 April 2017 - 09:05 PM
Before I drop US$135 on a new steering rack…
I have some slight play on my steering wheel before the steering engages (approx ½ inch left-right motion)... and it's coming from the rack (not the column or column clamp etc). Is it possible to strip/adjust/repair the rack to eliminate that? Kind of annoying as the rack is on 3years old with 10K miles on it
#2 cal844
cal844
  • 9,636 posts
  • Local Club: TFMOC
Posted 18 April 2017 - 09:21 PM
Check the U bolts are tight, also check that the rack is centered, are the track rod ends tight?
#3 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 18 April 2017 - 09:32 PM
All of those are good and tight. The play is inside the rack (from what I can tell where the splined pin mates with the rack internals)
#4 cal844
cal844
  • 9,636 posts
  • Local Club: TFMOC
Posted 18 April 2017 - 09:50 PM
Have a look at the link below
http://www.theminifo...i/#entry3431743
#5 nicklouse
  • 18,658 posts
Posted 18 April 2017 - 10:04 PM
But as there are no service parts available.
Just buy a new one.
#6 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 18 April 2017 - 10:31 PM
Order placed
... but I'll strip the old one down to see what the root cause is
#7 AeroNotix
AeroNotix
  • 267 posts
Posted 19 April 2017 - 01:21 AM
How have you determined this?
#8 Spider
  • 15,044 posts
Posted 19 April 2017 - 03:30 AM
Just buy a new one.
While not all parts are available, all parts you would replace in a normal overhaul / adjustment are available.
It will most likely be the plastic bush on the passenger's side that needs replacing.
#9 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 19 April 2017 - 03:39 AM
To answer AeroNotix... I determine this by removing steering column and getting an assistant to turn the splined pin by hand (yes it's that loose for I guess +/-5degrees), meanwhile I was under the car looking for movement at the ends of the rack (tierods). Nothing moving there so the play/slop must be inside the rack.
#10 tiger99
tiger99
  • 8,584 posts
Posted 19 April 2017 - 11:59 AM
It is just about possible that the pinion bearings are faulty. These may well be replaceable. Also, on most steering racks the yoke that holds the rack tightly in mesh with the pinion is adjustable by shims. So there may be some hope for the old rack.
However it should not have developed problems so soon. All too common these days due to bad manufacture. Or maybe they forgot to oil it? Racks used to (do they still?) come with the correct amount of oil already in them so you did not have to undo a gaiter.
Then there is the oil/grease controversy.... All I can say is that they were good for upwards of 100k miles with EP90 oil once upon a time.
#11 pete l
pete l
  • 1,374 posts
Posted 19 April 2017 - 12:13 PM
I allways thought they had oil in them, my minis in the 80s used to leak.
My MPI that I'm restoring has only a bit of grease on the inner joints.
Surely this can't be as good ?
Edited by pete l, 19 April 2017 - 12:13 PM.
#12 Spider
  • 15,044 posts
Posted 19 April 2017 - 01:11 PM
If they are greased, from my experience, they have a very short life. They were supplied like his at one point, it appears in an effort to overcome leaks.
Oil certainly is the shot, thy last a very long time then.
#13 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 19 April 2017 - 06:11 PM
If they are no longer oiled.  Can the greased newer ones just be oil or should they be stripped, cleaned of grease and then oiled?
#14 Spider
  • 15,044 posts
Posted 19 April 2017 - 08:25 PM
Yes ;D
