1986 City E - 998cc
Wondering if anyone can give me clarification here.
So, the engine isn't turning over, I've checked the following;
- Battery & Earth connections
- Connections on starter and solenoid
- Voltage at the solenoid
- Internal wiring inside the car
- Main Fuses
Both lights (orange & red) are lit.
I've pulled out the starter motor and replaced it as well as the battery. I then pulled off the starter relay found a fair bit of corrosion, cleaned it up, put it back together. NOW the relay clicks when turning the key to position 3 but nothing happens with the starter motor.
Busted starter relay?
Cheers,
Adam
