1400Cc Short Block. Jap Spec Exhaust And Custom Exhaust
8 replies to this topic
#1 pinkmini99
pinkmini99
  • 563 posts
Posted 26 April 2017 - 03:32 PM
First up is a jap spec back box that came off an jap import has been welded does not blow. Does sound like there rust inside. Do have a chrome finisher somewhere for it
£20
Next is a custom cherry bomb box with link pipe. It has a land rover down pipe welded to the end to make it a upswept. Has a lambda sensor on the upswept part ( get loads of people asking if it's a flames kit. Sounds awesome. I will cut the link pipe off if you would like me too.
£40
Finally up for grabs is a 1400cc block I brought last year freshly built
Spec to the best of my knowledge
Are
New oil pump
Centre main strap
276 cam
74mm pistons I think omega
New water pump
11 stud conversation
Duplex timing
24cc chamber
This block will need supercharging or turbo
Only selling as I'm going to 1.8t k series
£650
Location is droitwich
#2 Hegnirst
Hegnirst
  • 3,496 posts
  • Local Club: Hilltop Minis
Posted 26 April 2017 - 09:18 PM
£20
£40
Are
New oil pump
Centre main strap
276 cam
New water pump
Duplex timing
24cc chamber
£650
what do you mean the block will need supercharging mate? not work just hif44? lol
#3 minimans
minimans
  • 411 posts
Posted 26 April 2017 - 09:29 PM
Oh if only the shipping cost would be reasonable I'd have that 1400 off you in a flash!
#4 pinkmini99
pinkmini99
  • 563 posts
Posted 27 April 2017 - 04:59 AM
£20
£40
Are
New oil pump
Centre main strap
276 cam
New water pump
Duplex timing
24cc chamber
£650
Because of the low compression it will need a supercharger or a turbo
#5 Hegnirst
Hegnirst
  • 3,496 posts
Posted 27 April 2017 - 09:55 PM
£20
£40
Are
New oil pump
Centre main strap
276 cam
New water pump
Duplex timing
24cc chamber
£650
ah right i see, wass that the build for then?
#6 pinkmini99
pinkmini99
  • 563 posts
Posted 28 April 2017 - 01:00 AM
£20
£40
Are
New oil pump
Centre main strap
276 cam
New water pump
Duplex timing
24cc chamber
£650
Was for my pickup
#7 miniallsort
miniallsort
  • 4,723 posts
Posted 09 May 2017 - 03:26 PM
still avil;able
#8 pinkmini99
pinkmini99
  • 563 posts
Posted 09 May 2017 - 05:08 PM
still avil;able
Yes all still available
#9 pinkmini99
pinkmini99
  • 563 posts
Posted 17 May 2017 - 01:51 AM
Bump
