Duplex Timing Gear Replacement
3 replies to this topic
#1 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 04 May 2017 - 02:56 PM
Hi all,
As ever, I'm finding more things to replace, especially on second hand parts I've bought. I have an adjustable duplex timing set, however, the smaller sprocket as I've found today has a tooth smashed and looks like its scrap. Oddly, the rest of it is fine! The chain will be replaced but I want to replace the small gear. Now I can't find many of these online as replacement, the only one I've seen is this:
http://www.minispare...05.aspx|Back to
It's 20 tooth, looks similar, however it's from a pre A+, would it fit my MPi?
Regards
Steve
Edited by Steve220, 04 May 2017 - 02:57 PM.
#2 tiger99
tiger99
  • 8,584 posts
Posted 04 May 2017 - 03:20 PM
They are identical. See here:
http://www.somerford...age=page&id=113
Assuming it is a 1275 of course.
The Somerford web site, and another one which I forget, have a properly illustrated parts catalogue with all the relevant bits on one page. Much easier to use.
For best life you should consider changing both gears and the chain together. But lots of Minis do only low mileage these days, and in that case it may not matter very much.
#3 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 04 May 2017 - 03:45 PM
Thanks Tiger, will add it to the ever growing list!
The cam sprocket is almost new in comparison which makes me wonder about this kit's history. I'm replacing the chain as a matter of course anyway.
#4 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 04 May 2017 - 04:18 PM
IWIS chain is the one to get, got the swiftune duplex on both of mine, top bit of kit.
