Hello,
I've been stock piling pounds and pence for a while now and have enough (hopefully) to have a nice engine built for me.
I'm currently running a bog standard 998, which I do love chucking around but it just lacks a little in overall speed. I had considered buying a stage one kit from Maniflow, but the cost of that, plus getting it set up on a rolling road would make a £300 - £400 chunk of my money vanish.
So, I have a 1275 from an MG Metro sat in the garage that I plan on using as the donor engine. Now from reading, these engine should be chucking of 72 BHP from the factory, which will pretty much fall into my 70 - 80 BHP power bracket i'm aiming for. I want bags of acceleration. Top speed isn't an interest for me, the national speed limit is perfectly fine, so happy to keep the power lower down.
My proposed spec will be: (Loosely based on another thread on this forum)
ENGINE
Duplex timing gears
HIF 44 carburettor (which I think I have and will rebuild)
CYLINDER HEAD
Big valve head
Ported and polished
Roller tip rockers (1.3 or 1.5) (More reading required)
CAMSHAFT
Kent 266 (I'm aware this is near identical to the Metro Cam, but i listed this in case the current cam is worn)
GEARBOX
Minispares xpin diff
Centre oil pickup
3:4 Diff (Should already be fitted going by Guessworks engine number decoder)
Then throw on a nice Maniflow single box stage one kit.
To aid in acceleration would it be worth while looking at a lightened flywheel if money allows?
The car isn't used as a daily drive, it just my bit of fun on the side when I feel like a day off from cycling to work or if im going somewhere without my wife, as she dosn't really like being in the car.
