Indicators And Brake Light Electrical Nightmare.
Posted 10 May 2017 - 09:16 AM
Posted 10 May 2017 - 11:02 AM
Calling on all gods of the mini world Basically my mini has created a new fault, when i press the brake pedal while indicating it turns off all indicators and i have no brake lights. This doesn't happen all the time, very intermittent and very annoying. I thought it would just be a dodgey earth but if followed the loom back after the pedal switch and cannot find any issues. Doesnt happen if I disconnect the pedal switch. Any ideas would be welcome
Have you checked for a short in the pedal switch?
Posted 10 May 2017 - 11:44 AM
Posted 10 May 2017 - 02:20 PM
Disconnecting the break switch will stop it happening as that is the circuit causing the fault.
Posted 11 May 2017 - 11:17 AM
Posted 11 May 2017 - 12:12 PM
I would suspect the fuse box if it is an 80s or 90s mini. You may find that a voltage drop is causing this problem. Get someone to check the voltage at the rear when your foot is on the brake pedal.
Posted 11 May 2017 - 03:08 PM
Checked rear earths, doesn't seem to be an issue. If the earth was bad to the rear clusters, surely i wouldnt have any indicators, reverse light and so on at any point? And with it happening only when the brake is pressed wouldnt that indicate the feed for the brakes is shorting somewhere? Reluctant to give it to a garage, every time it goes to a garage it ends up with more problems
With a bad earth if the fault is on the brake light circuit even in the bulb holders then when the brakes are activated the brake light circuit,it will find another path and thats through the indicators or side lights, remove and clean all the connections and inspect inside the bulb holders, not forgetting the bullet connections on the tank side.
Posted 19 May 2017 - 10:04 PM
