I'm sure that I'm missing something really simple, but can't see what...
I need to remove the clutch pedal on my Marcos. I've undone the nut on the end of the pedal shaft, but it only moves a millimetre or so to the left even when tapped with a hammer. I've tried prising the other end (with the egg-shaped part on the end to stop the shaft rotating) but it won't budge.
Pedal springs are removed, still not going anywhere. Do I need to remove the clevis pins (Haynes manual says to do that after removing the shaft)? Doesn't seem as though it would make any difference. Is there some kind of retaining clip that I can't see which is holding it in place, or is it just stuck?
