Cellulose Paint - Hard Bits In Finish
9 replies to this topic
#1 Minitransition
Minitransition
  • 65 posts
Posted 13 May 2017 - 08:47 AM
So - sprayed all but last 2 panels on the mini in Almond Green cellulose. No problems at all. Bought one more litre from same supplier to finish the boot lid and the following happens, same gun, same thinners, same environment.........
Sprays on  - looks fine.
Leave it 5 mins, little hard bits appear (like grit) on the surface, looks like someone has thrown sand on it.
When dry, flatting reveals the hard bits are blue and very hard - paint sands, blue lumps won't.
Old paint sprays fine.
Cleaned gun, air filter on compressor, area dust free.
I'm thinking defective supply of paint with some fault in the 'blue' component.  Paint supplier happy to provide more paint, but how to check problem solved - rubbing it down is really hard work with each 'bit' needing individual finger sanding to get it flat. Using a bock leaves the hard bits exposed. ARGGGGHHH
I was so close to finishing - anyone else been supplied defective paint or is the problem elsewhere?? Can't think where, reverting to old paint (non left now) solved problem.
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2017 - 09:04 AM
I take it you didn't pass the paint through a micro strainer when putting it in the gun pot?
#3 Minitransition
Minitransition
  • 65 posts
Posted 13 May 2017 - 09:06 AM
No - never have ! But if the blue bits are removed then it will be the wrong colour?? Will be worth a try to see what I collect. Thanks
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2017 - 09:18 AM
So the blue is actually pigments then?
I would pass some through and see what collects. Perhaps one of the tints they used is past it's best?
Either way, I would be reporting the problem to the supplier.
Good luck with it.
Ben
#5 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 13 May 2017 - 09:47 AM
Strain it with a 100 micron filter
#6 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 13 May 2017 - 09:49 AM
+1 on what Ben says! and you can buy a small strainer that goes in the bottom
of a Gravity feed spray gun most Bodyshop suppliers have them
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2017 - 11:43 AM
These are the in pot filters i use
https://www.fastmove...k-of-10pcs.html
#8 Stu.
Stu.
  • 912 posts
Posted 13 May 2017 - 06:59 PM
This is why you should always pass the mixed paint through a fine cone filer into the gun pot and use the pot filters while spraying.
Hope you get it sorted, but it sounds like you'll need to take the paint back to primer to me.
#9 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 21 May 2017 - 07:26 PM
Or use this setup http://www.3m.com/3M...93193985&rt=rud
#10 Minitransition
Minitransition
  • 65 posts
Posted 27 May 2017 - 01:45 PM
Just to close this down - used a 150 filter and much 'crap' in paint. Took back to store as colour wrong anyway. No problems with refund. Bought paint from elsewhere - no further problems - vehicle panels finished today !!! Done the last 2 panels 4 times now !!!
They are mystified too but hopefully will sort the issue to save their business !
