Hi,
I have searched alot, but I can't find anything which I haven't tried yet without taking the clutch to bits..
Recently rebuilt my engine, runs great but the clutch is dragging quite badly. I can't select gears from stationary without turning the engine off and starting in gear, with the clutch down. This alone shows that the clutch is partially disengaging. It's a 1275 SPi by the way, clutch plate and pressure plate have been replaced with the minispares injection kit, along with release bearing and o-ring. I am getting full movement on the clutch arm, set at 6.5mm throwout gap.
I have read online, only a couple of people have had this, that the pressure plate can be faulty and not releasing fully. I still have my old pressure plate, which still has the machining grooves on the clutch face, it's hardly even worn. I am tempted to try and fit this and see how I go. Has anyone else had an issue with verto pressure plate being too "tight"?
Clutch arm has been replaced, as have all the clevis pins. Slave is the correct kind and like I said, I am getting full travel on the clutch plunger.
London to Brighton is on Sunday, and I'm going to that. I am tempted to leave it for now, as it is driveable, and sort it out after because I don't want to miss it. How difficult is it removing the clutch assembly with the engine in the car? I've got all the tools to do it, but I am reluctant to take the engine out with it being injection theres alot to remove and I don't really have time!
Cheers,
Cam.
Edited by RooBoonix, 16 May 2017 - 11:56 AM.
