I have a problem getting the sleeve that holds the detent spring and ball into the right side differential case. It slides in part way but won't mesh with the inner spool (I think its called) and seat flush with the side of the case. The motor and transmission are both new and are installed in my '84 saloon. The differential side case was removed to try to free up a stuck shifter rod in the transmission that was not built by me. The action did free the stuck shifter rod but my moving it about has apparently moved the inner spool out of position and I think is keeping me from reinstalling the sleeve.
Is there a way of getting the sleeve and inner spool in the right positions so I can reinstalled the differential side cover?
Jack
