Hi all,
Following my last post a week or so ago, ('cv joint woes'), I have checked everything, here's where I am.....
bearings, new,
hub and split conical washer smooth and nothing stopping it closing together properly,
all Haynes torque setting done (single hole cv 190 lb/ft),
tightened with spacer before full torque up on conical split washer,
No wobble top to bottom which suggests the swivel joints are ok, they are new too,
slight play left to right.
I have tightened the bearings up in the hub without the spacer to see if the hub had worn and the spacer was a tad too wide, but got the same result (well nipped up not full torque)
The CV joint is not new but moved ok so kept it on rebuild.
Am at my wits end with this problem as I just cant figure out what is causing the problem.
ALL help appreciated including coming to my house in Warrington to have a look lol
Many thanks as always,
Graham
