Rear Fog Light
12 replies to this topic
#1 EasterBern
EasterBern
  • 52 posts
Posted 24 May 2017 - 04:49 PM
I don't like the square fog light beneath the bumper, looks like the late 70s afterthought that it is!
I was thinking of getting a Landrover Defender rear fog light, like this:
http://www.ebay.co.u...RQpzEz_BBASusoA
And then fitting a chrome surround for a more classic look like this:
http://www.ebay.co.u...p-/170345882437
And then mounting this on the boot lid.
Alternatively perhaps a Defender rear light unit adapted to be a fog light:
http://www.ebay.co.u...zgAAOSwMgdXyAJ6
But I'm not sure of the legality of that. And whilst we are on the subject of the law, does it matter which side it goes on?
What do we think of these ideas, or are there any better ideas or suggestions?
Cheers,
Bern.
Edited by EasterBern, 24 May 2017 - 04:50 PM.
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 24 May 2017 - 04:59 PM
http://www.59-speed....builderpro.com/
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 24 May 2017 - 05:14 PM
I made my own from stainless, Jb fabrications (find him on Facebook) makes and sells similar.
13103495_1003434839742468_63502410198970
Edited by alex-95, 24 May 2017 - 05:14 PM.
#4 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 24 May 2017 - 05:48 PM
If you have Mk3 lights you can put it in the lower most reflector, I use an LED blub and it works great.
#5 MikeRotherham
MikeRotherham
  • 987 posts
Posted 24 May 2017 - 09:14 PM
Do you mean turn the offside reversing light into the rear fog light?
That would make the back end cleaner looking.
#6 EasterBern
EasterBern
  • 52 posts
Posted 25 May 2017 - 06:56 AM
Brilliant, thanks for the replies, I think I'm going to make something a bit like Alex-95's.
Cheers,
Bern.
#7 DomCr250
DomCr250
  • 667 posts
Posted 25 May 2017 - 10:42 AM
Yes, you can drill the lower reflector out and put a 12V LED inside - you need a hole cutter and a 12V LED cluster bulb.
I wish I had done this on my two other rebuilds, with those I recessed the fog light into the rear valance, to be honest it looks OK but not as clean as hiding it in the cluster.
I can take some picture if you need them.
#8 tiger99
tiger99
  • 8,584 posts
Posted 25 May 2017 - 07:31 PM
Modifying MK 3 lights is an extremely neat solution if you can satisfy the legal requirements.
You will need the legally required distance of 100mm between the edge of the ILLUMINATED AREA of the stop lights and that of the fog light. Be aware of light bleeding through where you don't want it. You need to keep some reflective area too. The Motor Vehicle Lighting Regulations are available on line somewhere, or the IVA tester's manual will help.
A completely clear lens, which is available, and the correct colour of LEDs for each lamp may be helpful if the standard lens is not suitable. You may need to add internal partitions to keep the light from the fog lamp not bleeding into the brake lamp area and vice versa. I used adhesive aluminium tape for that once, but have forgotten which car it was.
If you are successful, please post some pictures. It seems that it has potential promise. I hate the ugly, tacked on reversing and fog lights too.
#9 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 02 June 2017 - 03:22 PM
So on this light it's from the edge of the top red section to the edge of the bottom red reflector?
(basically the size of the reversing section)
Is that not less than 100mm ???
Edited by r3k1355, 02 June 2017 - 03:22 PM.
#10 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 02 June 2017 - 08:29 PM
Cheers ukcooper :)
If people want a more subtle fog light, we also make them so they can be tucked away and mounted on the rear subframe too.
http://www.59-speed....subframe-mount-
Thanks,
Ian
Edited by 59 Speed, 02 June 2017 - 08:30 PM.
#11 Richie83
Richie83
  • 1,495 posts
Posted 02 June 2017 - 09:04 PM
I was going to post this very same question. Thanks OP. Oddly was looking at 59 speed last night on eBay too.
#12 r3k1355
r3k1355
  • 585 posts
Posted 06 June 2017 - 06:23 PM
How can this be possible on Mk3 lights??
From the brake lights to the reflector is barely 50mm, sure this is not legal?
#13 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 06 June 2017 - 07:42 PM
I to didn't like the hanging down of the square fog light so fitted a mk2 Ford Fiesta rear fog lamp. Their mounted on a angle and a slight mod fits it nicely on the curve of the minis rear valance.
Edited by Allrounder, 06 June 2017 - 07:43 PM.
