And steam comes out of the cylinder head little valve which is near the bypass hose I believe.
Recently put a second hand engine in that was alright , bores a bit worn and 2 cylinders had slight bit of surface rust, but when
I compression checked it came out at 170psi 190psi 170psi 185 psi number 1 being timing chain side.
Are these figures reasonable , bearing in mind the 2 170 psi cylinders were the slightly rusted ones.
So anyway Ive been running this engine up for about 100 miles or so , and its had oil and filter, all new distributor parts, valve clearances checked , and new plugs (ngk bp7es) are they the correct plugs? Ignition timing set at about 1200 rpm vac disconnected to 10' btdc.
Fuel mixture I set by sound , and plug colour, Ive got it running okay , idling okay , and it pulls very slowly under load in 3rd gear, Im assuming its fuelling alright , but am not 100% I keep checking plug condition and they are slightly tan colour with weird little mould like deposits on them , is this indicating an okay mixture etc...
So shes started overheating after about 10 minutes of driving, the guage slowly goes up and at about 3/4 of the way i turn her off and refill her and get home after letting cool down for 10 minutes.
Aux belt is pretty tight , water pump was an old one I put on but im assuming it works, and thermostat I tested and it looked like it opened.
Any thoughts?
