Fse Power Boost Valve Vk-384-Mg1-H Rover Mini 1.3 Litre Mpi Twin Port 1997-Onwards
7 replies to this topic
#1 MINIPDB
MINIPDB
  • 10 posts
Posted 27 May 2017 - 11:13 PM
Has anyone fitted one of these - are they any good ?
#2 Steve220
Steve220
  • 5,055 posts
  • Local Club: BMC
Posted 28 May 2017 - 06:57 AM
What are you trying to achieve? And what level of modification is your engine. The power boost valve is a rising rate fuel pressure reg and can easily over fuel your engine causing bore wash. I'd rather save and go for independent engine management.
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 28 May 2017 - 10:09 AM
injectors work within a pressure range and its not that big.
#4 MINIPDB
MINIPDB
  • 10 posts
Posted 28 May 2017 - 01:07 PM
Was looking for improved power - engine is std apart from lightened flywheel - roller tip rocker and k&n air filter - my understanding is that ltiile can be done with the std Ecu ?
#5 MINIPDB
MINIPDB
  • 10 posts
Posted 28 May 2017 - 01:09 PM
What is the best way to improve performance for a twin point ?
#6 Steve220
Steve220
  • 5,055 posts
  • Local Club: BMC
Posted 28 May 2017 - 02:14 PM
Correct. You can get a lot more power from cylinder head work and a good cam.
#7 MINIPDB
MINIPDB
  • 10 posts
Posted 28 May 2017 - 02:47 PM
ok thank you for your reply
#8 jamesmpi
jamesmpi
  • 1,940 posts
Posted 29 May 2017 - 10:30 AM
As above. Decent cylinder head and cam are your better options (I have stage 3 head and Swiftune SW5 cam)
I would only fit a fuel boost valve in conjunction with these mods. Not instead of.
But as with all mpi engines, the biggest restriction is the ECU
