Electronic Ignition System - Help And Advice Needed Please
12 replies to this topic
#1 Sunflower28
Sunflower28
    Starting My Mini Up
  • 4 posts
Posted 30 May 2017 - 12:05 PM
Hi there,
I have a 1991 Rover Mini Mayfair (automatic). I'm looking at putting in an electronic ignition system, can anyone suggest any that are particularly good, or any to avoid?
Thank you very much.
#2 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 30 May 2017 - 12:29 PM
Look for a 65d dizzy, coil and module wiring on ebay
#3 Dusky
Dusky
  • 5,322 posts
Posted 30 May 2017 - 01:10 PM
I strongly advice against buying a dizzy.
The original dizzy will have the right advance curve for the engine, the chances of the 65dm4 having the right curve are very slim.
Your car will probably have a Lucas 59D ATM. You can get electronic conversion kits from simonbbc (Powerspark). They keep the original dizzy, and won't alter the advance curve .
Be cautious with new dizzies sold by accuspark, Powerspark and the likes. They most of the time don't have the right curve either. My own dizzy came with a whopping 38° of inbuilt advance.
Edited by Dusky, 30 May 2017 - 01:12 PM.
#4 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 30 May 2017 - 01:40 PM
I use 65d on my 998 engines and they drive well
No issues
#5 Dusky
Dusky
  • 5,322 posts
Posted 30 May 2017 - 01:47 PM
No issues
And I cross the m20 with my eyes closed without problems.
With all respect "65dm4" means nothing without knowing wich one you're exactly using.
https://www.google.b...gmmSv2uPsO5I9qQ
#6 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 30 May 2017 - 01:55 PM
65 D is the electronic dizzy that the late carb cars have as standard
#7 Dusky
Dusky
  • 5,322 posts
Posted 30 May 2017 - 02:01 PM
Did you click the link? There are a gazillion different 65dm4 dizzies around, all with different curves.
#8 cal844
cal844
  • 9,651 posts
  • Local Club: TFMOC
Posted 30 May 2017 - 02:12 PM
The link shows 25 D etc?
#9 Dusky
Dusky
  • 5,322 posts
Posted 30 May 2017 - 05:33 PM
65dm4 starts from page 16, a lot of blanks to fill in too.
#10 petey81
petey81
  • 1,341 posts
Posted 30 May 2017 - 05:36 PM
Never assume any dizzy has the correct curve!
#11 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 June 2017 - 10:50 PM
If your current distributor is in good condition fit a electronic ignition kit as mentioned above, less that £30 and there is a post in the FAQs Electrical Section on a step by step fitment and the correct way to wire it.
#12 tiger99
tiger99
  • 8,584 posts
Posted 03 June 2017 - 09:50 AM
In this day and age it is worth thinking about fully mapped ignition. Then you can have any curve that your engine needs.
#13 andyapanel
andyapanel
  • 626 posts
Posted 03 June 2017 - 03:25 PM
I have an H+H ignition solutions distributor on my 1098 pickup which works fine and an MTK 007 magnetronic unit on my 998 Racing Green The latter died recently after 100000 miles and I am not complaining. I have replaced with another. I would recommend both.
