Wiper Fuse Location
1 reply to this topic
#1 toplessmini
toplessmini
  • 492 posts
  • Local Club: none on the island....
Posted 30 May 2017 - 08:47 PM
Silly question but can you tell me where the wiper fuse is located on my 99 MPI Cooper?
Thanks in advance......
Edited by toplessmini, 30 May 2017 - 10:03 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 May 2017 - 10:13 PM
Here is the listing taken from the FAQs Electrical Section here on TMF showing each fuse by number
Fuses (twenty four-fuse fuse block)
Fuse number Rating (amp) Circuits protected
1 15 Heated rear window
2 15 Reversing lights, stop lights, headlight dim/dip*,direction indicaton relay
3 15 Auxiliary cooling fan
4 15 Headlight dim/dip*
5 15 Heater blower motor, sunroof motor*
6 15 Wipers/ washers
7 20 Headlight flasher, horn, anti-theft alarm*
8 10 Tachometer*, engine management ECU*, fuel pump relay*, anti-theft alarm* If Fitted
9 10 Radio/cassette, cooling fan relay, automatic gear selector light* If Fitted
10 10 Radio memory*, interior light, direction indicators, hazard flasher,theft alarm LED* brake test
11 10 Fuel pump* Inj Cars
12 10 Starter signal
13 10 Left-hand, side and tail lights
14 10 Right-hand, side and tail lights, instrument illumination
15 10 Left-hand headlight main beam
16 10 Right-hand headlight main beam, main beam warning light
17 10 Left-hand headlight dip beam
18 10 Right-hand headlight dip beam
19 20 Not used
20 15 Not used
21 10 Not used
22 20 Not used
23 Not used
24 10 Rear fog light
As well as the Main fuses there are Inline Fuses in the engine compartment behind the Air Filter on the Bulkhead
In-Line Fuses situated behind air-filter on the bulkhead:-
15amp - Purple/Orange Wire
Hazard Warning & Interior Lamps
15amp - Brown/Orange Wire
Dim-Dip Lighting (Where Fitted)
10amp - Blue/Orange Wire
Rear Fog Guard Lamps
15amp - Blue/Red Wire
Auxiliary Cooling Fan (where fitted)
