what air pressure should I use to spray gravitex unipol thanks
Spraying Gravitex
Posted 03 June 2017 - 07:52 AM
Posted 03 June 2017 - 08:44 AM
I think it states between 40 - 70 psi which would be with the trigger pulled on the Shultz gun. I would start low and work up until you get the desired texture you are after. I would also stand the tins in warm water to soften the stone chip prior to starting. Test the texture on a waste panel / surface. The fact the weather is warmer at the moment than in the winter months will mean the substance is already slightly more viscous which helps as less pressure is required to apply it..
Posted 03 June 2017 - 01:53 PM
thanks ive just finished it looks ok
Posted 03 June 2017 - 06:52 PM
photos...? (need to do it myself sometime soon)
Posted 04 June 2017 - 11:09 AM
very nice!
