Hi,
What spark plug gap size should be used when running a MegaJolt ignition system? To date I've been using NKG BPR6ES set to default gap (0.036"). Runs fine, but I'm just curious if it is 'optimal'.
Regards,
Colin.
FYI, my engine is 1380cc, stage 4-ish head (35.6mm Inlets, 31mm exhausts and an lot of flow/porting), AC Dodds AC-RS+ cam, HIF44, and MegaJolt V3 running a MAP sensor.
