Sad day for my Monte. Over the weekend I took (or the plan was at least) my 94 SPi on a 900 mile round trip. 450 there and 450 back. The ride was great. Car drove at a steady 4k for nearly the entire time without a hitch. They way yester, not so much. My upper rad hose burst (which was not old) and motor got SUPER hot. What really kills me is that the temp gauge never changed. Only way i realized something was up was that the oil pressure started to drop. I have a mechanical gauge installed. Typically reads 60lbs @ 4k but was dropping and went down to 40lbs before I could get it shutdown. By the time I was able to get out of the way of the tractor trailers doing 70+ mph, the upper hose completely let go and the steam was so thick it looked like the car was on fire. Good times! The oil was clearly thinning out majorly due to the heat. After about 30 minutes (waiting for a tow truck) I gave it a crank and it fired right up. Turned it off instantly though. Worried it was seized.
So, where does the temp gauge get its temp reading from? Both the sensor in the rad and the sensor in the intake mani are new. The temp gauge opperatesas it should it seems. When I replaced the mani sensor I cleaned out what little build up was in there. Rad is a newer and has been changed regulary. It really kills me that this happened and I had no rea idea. Is this a major design flaw? If the belt were to let go, how would you know if the temp is reading from somewhere not really in the correct path?? Just need to know why I had no warning from my gauge.
I installed a head from Calver and it has the original style temp sensor port. If/when this car is back on the road, I am SOOOOO installing a sensor there and running a separate gauge from it so I will never have this happen again.
