So i got the lowered spax coilover kit (the yellow ones.) and I can't seem to figure out how the new brackets go on. Anyone got pictures to share? Thank you!!
Spax Coilover Install Help!
Posted 06 June 2017 - 03:34 AM
Posted 06 June 2017 - 07:48 AM
which brackets are these then?
bolt on to the bottom arm through the shock mount hole.
bolt onto the the point where the upper shock mount fixes.
by the way ´the angle the shock makes is totally wrong to work well.
Posted 06 June 2017 - 08:10 AM
https://usa.minispor...rsion-kit.html#
This kit. I know the two large brackets are the top shock mount. But idk how the 2 square C shaped one and 4 flat ones work.
Posted 06 June 2017 - 08:25 AM
The C Brackets bolt on under the top ball joint nut. Then 2 of the flat brackets go either side of these back to the original shock mount holes (for each side).
Posted 06 June 2017 - 08:26 AM
over the top arm. they only go one way. see above.
Posted 06 June 2017 - 08:30 AM
Ohhhhh i see. Okay thanks! ill try to finish it up tomorrow!
