Non-Genuine Ball Joints Seem Like Garbage
34 replies to this topic
#1 AeroNotix
AeroNotix
  • 267 posts
Posted 11 June 2017 - 02:28 PM
I bought a pre-made swivel hub from minisport a couple of months ago. The one that comes prefitted with ball joints and apparently shimmed properly.
This past weekend I went to replace my tie bars (they had a slight S kink to them), obviously being a mini one of the bolts was rusted on so I removed the lower suspension arm along with the tie bar and hammered it out. When I went to replace everything, needing to refit the lower ball joint I found that the threads were completely ruined. Bare in mind this is a new ball joint, installed once and removed once both times the fitting and removal went very smoothly without needing to overly hammer/bash the ball joint to get it out.
Simply put, the ball joint's tapered shank bolt is utter and complete garbage. It has less than 2000km on it and has been treat well when serviced. I just don't understand. The grade of material used seems also quite suspect. It does not seem to have been hardened and is easily scuffed, bent and marred.
I have several genuine ball joint kits that can use and replace that bolt with. The difference in quality is ridiculous. The bolt is hardened, for example.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 11 June 2017 - 02:58 PM
Ive given up with new ball joints they never go together properly the machining is terrible....
Can any one recommend were to buy good ones!!!!!
same with wheel bearing unless you buy timkins
#3 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 11 June 2017 - 03:12 PM
wheel bearings rhp ball bearings are good, but a lot of whats out there is trash, ball joints i try and find nos but thats getting hard, and major brands just out Chinese in a box :(
#4 AeroNotix
AeroNotix
  • 267 posts
Posted 11 June 2017 - 03:26 PM
What are the best choices?
I just want a ball joint that a) doesn't fall apart, b) favours safety/longevity over fanciness and above all else c) consistency. The genuine parts that are available on minispares/minisport so far seem reasonable. They get very stiff, very quickly (likely I need to start lapping before final fitment?) but the non-genuine ones that Minisport at least carries are utter rubbish! I can't believe they're selling them where the tapered shank bolt is unhardened? Wouldn't that be part of the specification when making a non-OEM part?
#5 sledgehammer
sledgehammer
  • 3,107 posts
Posted 11 June 2017 - 03:31 PM
I bought some mini  QH track rod ends (they said they were on the box - eBay)
box looked real
track rod ends were a smaller dia on the taper shaft / shank appeared soft & I could feel them stretch as they nipped up
went in the bin - annoyingly I couldn't find the seller - bought 6 months earlier
problem is they weren't particularly cheap
so cheap isn't always bad , & £xpensive isn't always the best
it's 'word of mouth' that is more important
I always try minispares for price , then eBay for comparison , but for most safety critical parts minispares
Edited by sledgehammer, 11 June 2017 - 03:35 PM.
#6 1984mini25
1984mini25
  • 8,785 posts
Posted 11 June 2017 - 03:33 PM
Delphi Ball Joint kit (one hub) - TD229W at around £20.54 each
And I've just fitted a Firstline front wheel bearing, witch apart from the shocking delivery (took 5 days to dispatch) Fitted and torqued up ok and seam to be well made.
Wheel bearing kit, front disk type - FBK027 at Around £22.24 each.
#7 AeroNotix
AeroNotix
  • 267 posts
Posted 11 June 2017 - 03:35 PM
What can I do if I torque up the dome nut with no shims + grease and the tapered bolt still doesn't move? Will lapping improve things?
#8 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 11 June 2017 - 05:23 PM
Delphi balljoints are good. I've had the same trouble with cheap balljoints!
#9 nicklouse
  • 18,667 posts
Posted 11 June 2017 - 05:55 PM
add shims to get required movement.
#10 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 11 June 2017 - 06:08 PM
Shims make them looser what your describing is normal.
#11 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 11 June 2017 - 06:59 PM
I've never had an issue with the ones we sell at Somerford Mini.
I know you will think that I'm just saying this as I work there. But I work in the workshop, fit them regularly and the fit is perfect. The rubbers do not crack after 2 miles either!
#12 grizzler73
grizzler73
  • 300 posts
Posted 11 June 2017 - 07:15 PM
I got some NOS Quainton hazel ones off ebay, I only have 2 on my GTM so paying a bit more is not as bad. Otherwise I have minispares metro ball joints for the front alloy hubs which look ok, I would recommend Delphi though. They seem well made.
#13 Rorf
Rorf
  • 866 posts
Posted 11 June 2017 - 08:22 PM
Now why on earth would you do that :mmkay:
#14 AlexMozza
AlexMozza
  • 1,248 posts
Posted 11 June 2017 - 08:44 PM
I'm sorry, but right here is why so many people have issues with them failing!
#15 nicklouse
  • 18,667 posts
the nuts were not stainless were they?
