12G295 And Standard 998 Heads
6 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,267 posts
Posted 12 June 2017 - 05:48 PM
just wondered, how far apart is a 12g295 head from a standard one? More of can you mod the standard one to be like the 12g295?
I know that would be a lot of work, but is it possible? I see the inlet of a 295 is 30mm while the standard i think is 27. the exhaust valves seem to be the same size...
I think on the standard head you can remove 3mm from it before any skimming problems.
Ive got a 12g940 head and that is massive compared to the standard 998 but the exhaust ports arnt that much different, its mainly the inlet i think... Just wondered as i may stickw ith the head i have and port it and put bigger valves in it...
#2 Dusky
Dusky
  • 5,322 posts
Posted 12 June 2017 - 06:39 PM
A ported standard 998 head can be a lot better than a 12g295. 295 has big inlet tracts and small valve seats.
#3 Avtovaz
Avtovaz
  • 1,267 posts
Posted 12 June 2017 - 06:47 PM
so whats best to do to them? valve sizes and whats the best way to port it?
#4 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 12 June 2017 - 08:12 PM
It depends on your application. What's the spec of the engine and what will it be used for ?
Bigger ports will flow more air, but at the expense of velocity reducing volumetric efficiency until higher rpm's are reached.
Phil.
#5 Avtovaz
Avtovaz
  • 1,267 posts
Posted 12 June 2017 - 08:44 PM
road, 998 cc , mg metro cam. I see the 295 has bigger inlet, all seem to have 1" exhaust.
Just reading about this now a bit, seems you dont do much to the exhaust ports, keep the speed up, but get as much as you can out of the inlet almost.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 12 June 2017 - 09:37 PM
http://russellengine...cylinder-heads/
Read that,
Ac
#7 timmy850
timmy850
  • 3,394 posts
  • Local Club: MITG
Posted 12 June 2017 - 11:04 PM
You also need to consider the desired compression ratio of the engine as the 12G295, 998 and 12G940 have wildly different chamber sizes.
