Replacement For This Shift Lever?
8 replies to this topic
#1 soulslinga
soulslinga
  • 63 posts
Posted 17 June 2017 - 07:09 PM
Hello - I have a mostly original '65 countryman that was ordered left hand drive out of factory. My shift lever snapped, but I can't find the part that matches it. I understand normally part number 22A269 would work here, but that part doesn't match. I suspect it may be an old aftermarket part. Any help replacing this simple thing? You can see the part and where it broke in the attached photo. It is currently held in with a pin.
1965 850cc Austin Mini Countryman
Mostly original, Factory Left Hand Drive
shift lever located between the driver and passenger seats
don't have to lift the shifter for reverse
Edited by soulslinga, 17 June 2017 - 07:13 PM.
#2 nicklouse
  • 18,605 posts
Posted 17 June 2017 - 07:45 PM
that will be an aftermarket kit not a genuine part but a part of a period accessory.
full pics of the bits on the car.
#3 Spider
  • 14,909 posts
Posted 17 June 2017 - 08:01 PM
That looks like an SPQR Shifter which was an after market accessory of the era.
I really doubt you'd find one, though you might get lucky.
Can that one be welded back together?
#4 nicklouse
  • 18,605 posts
Posted 17 June 2017 - 08:13 PM
Attached File  spqr.jpg   76.41K   38 downloads
this look like the rest of it?
#5 Rorf
Rorf
  • 866 posts
Posted 18 June 2017 - 06:56 AM
Could easily be welded or brazed back together
#6 soulslinga
soulslinga
  • 63 posts
Posted 18 June 2017 - 04:06 PM
Hello - it does - I have to take a look tomorrow to be sure - is that something you would be selling? or just a photo you found?
#7 soulslinga
soulslinga
  • 63 posts
Posted 18 June 2017 - 04:08 PM
I'm going to look into the welding... what would be involved if I had to replace the whole mechanism, or go back to original..?
#8 nicklouse
  • 18,605 posts
Posted 18 June 2017 - 06:08 PM
to go back to original you would just need a magic wand gear stick, and then learn where your gears might be, no i dont have either.
#9 soulslinga
soulslinga
  • 63 posts
Posted 19 June 2017 - 09:08 PM
welder was able to fix it - thanks everyone.
