What Coil
11 replies to this topic
#1 chadd123
chadd123
  • 212 posts
  • Local Club: Wirral-minis
Posted 19 June 2017 - 09:03 PM
What coil do ineed for a 1275 engine been told its not a gt engine number is 38g527e
the one in it is getting very hot
#2 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 19 June 2017 - 09:17 PM
Coils get hot due to the oil in them. What is the problem with it?
#3 chadd123
chadd123
  • 212 posts
Posted 19 June 2017 - 09:29 PM
when i have the ignition on with or with out the engine running the coil gets very very hot
could it be wired in correct
#4 nicklouse
  • 18,998 posts
Posted 19 June 2017 - 09:31 PM
coils are filled with oil to help them cool.
as to what coil should be fitted it depends which dizzy and ignition system is fitted. and then if it has been modified at all.
but what problem are you actually having with the engine running?
#5 chadd123
chadd123
  • 212 posts
Posted 19 June 2017 - 09:48 PM
standard 1275 with a very old dizzy small cap the coil gets very hot when the car is running
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 19 June 2017 - 10:13 PM
Apart from the body of the coil getting hot, what problems is it causing?
#7 chadd123
chadd123
  • 212 posts
Posted 19 June 2017 - 10:24 PM
I guess its not causing any problems just wasnt happy about how hotvit was getting
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2017 - 10:32 PM
What feed do you have to the coil direct 12v ? if so the coil should measure 3-3.5ohms between the coil + and - terminals
#9 carbon
carbon
  • 2,590 posts
Posted 20 June 2017 - 04:55 PM
If the coil casing is too hot to keep you hand on it then it's probably running too hot.
Reasons for a coil getting too hot include:
- wrong coil, such as ballast duty coil fitted to non-ballast system
- dwell angle set incorrectly (points system only)
- coil feed voltage running too high
Best not to leave a coil on for any length of time without engine running.
#10 chadd123
chadd123
  • 212 posts
Posted 21 June 2017 - 10:06 PM
thanks you have understood my problem exactly,i,am going to replace thecoil when i find out which one it should be,and iam a bit worried about feed voltage being too high as the wirings iffy
#11 nicklouse
  • 18,998 posts
Posted 21 June 2017 - 10:13 PM
If your wiring is iffy you are more likely to have to low a voltage.
But you need to find out what dizzy you have and what coil is fitted and if it is ballasted or not.
And as above check the resistance.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 June 2017 - 12:16 AM
What year is the car and what colour wires do you have on the coil + connection
