Large Rear Spotlight
8 replies to this topic
#1 Shaggy33
Shaggy33
  • 311 posts
Posted 19 June 2017 - 10:35 PM
I love the look of the round chrome spot lights bolted to the back of minis on the boot. I see that mini spares do one but it's £170 ish. Can't I just buy a cheap front spot and mod a right angled Bracket for it?
Has anyone done this, if so any pics of fitment?
#2 Cooperman
  • 23,355 posts
Posted 19 June 2017 - 10:42 PM
They are not spotlights, they are Lucas 5" back mounted fog lights.
#3 DR3AM-W3AVUH
DR3AM-W3AVUH
  • 48 posts
Posted 20 June 2017 - 12:12 AM
Look on ebay for Lucas SLR576. You can reproduction ones pretty cheap
#4 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 20 June 2017 - 07:14 AM
Here you go :)
I used a spotlight for mine, but have now changed to LED reverse light mounted on the subframe because Im going in a different direction with mine....
#5 Shaggy33
Shaggy33
  • 311 posts
Posted 20 June 2017 - 10:12 AM
Thanks guys I'll take a look...
#6 Shaggy33
Shaggy33
  • 311 posts
Posted 20 June 2017 - 10:17 AM
How have you mounted yours minifreek?
#7 minifreek1
minifreek1
  • 1,260 posts
Posted 20 June 2017 - 12:18 PM
Drilled a 10mm hole in the bootlid for the bolt for the bracket and bolted it, then drilled a smaller hole for the reverse wire to pass through.... simple....
I did need to extend the reverse wire from the loom, through the bootlid, then to the spotlight fitting. The earthing point is through the casing of the spotlight itself and also through the bootlid too...
#8 Shaggy33
Shaggy33
  • 311 posts
Posted 20 June 2017 - 10:05 PM
Done the deed, put a little second hole for wire as you suggest minifreek with grommet. Found brand new WiMac fog lights bought ages ago and never sued! Yet to wire it up but have extended wire ready to run across to meet up with existing reverse light wire. Only had 6 inch so a little larger but it gives the look and I preferred the higher mounting rather than level with number plate.
Chuffed with It, thanks for advice
#9 Shaggy33
Shaggy33
  • 311 posts
Posted 20 June 2017 - 10:06 PM
Just need the mk2 non reverse light clusters now!
