Fuel Pick Up
Posted 21 June 2017 - 10:18 PM
The reason I am asking is I keep loosing fuel pressure after about 15 miles.
I have changed the fuel pump ( electric in line ) and have taken the pressure Reg apart to see if it was sticking but that is fine.
There is an earth straight from the pump to the battery and I have an led on the power to the pump which stays on when the pressure drops. So the last thing I can think of is the pick up getting blocked.
Thanks in advance
Posted 21 June 2017 - 10:50 PM
Posted 21 June 2017 - 10:51 PM
you do have a vented filler cap fitted?
I would be running with one of those plastic lost cap caps that definatly vents to see if the problem goes. if it does then you have the problem found if it does not then you need to go further.
if there is a filter in the tank it is not a service part.
Posted 21 June 2017 - 11:05 PM
just to highlight the saloon caps are not vented.
Posted 22 June 2017 - 01:56 AM
There is a fine mesh nylon sock over the end of the pickup tube.
When my buddy started having a similar problem we sent one of those inexpensive bore scopes down the tank filler....what we found was someone has "sealed" the tank with a product that didn't work very well and large pieces had peeled off and would block the pickup tube, they looked like pieced of latex paint peeled off a wall.
He bought a new SS tank, as the repair cost to take the tank apart, clean all the old sealer off and reseal the tank was almost as much.
Posted 22 June 2017 - 07:20 AM
Posted 22 June 2017 - 12:38 PM
They are
Posted 22 June 2017 - 12:46 PM
They are
oh no they are not. there is a separate vent on the top of the tank.
oh I was on about the original style caps.
Edited by nicklouse, 22 June 2017 - 12:53 PM.
Posted 23 June 2017 - 05:36 PM
I will be removing the sender unit and having a look at the filter on the end of the pick up. I will let you know how I get on.
