Compression Readings For 1275Gt
1 reply to this topic
#1 bevyid31
bevyid31
  • 34 posts
Posted 22 June 2017 - 12:49 PM
These are the readings, 1 being nearest to radiator
1. 159 PSI
2. 132 PSI
3. 132 PSI
4. 159 PSI
The car runs fine though I am getting a puff of smoke on
Overrun when I have just put my foot down. Also the exhaust has a lot of black soot on it but the plugs seemed ok.
Could there be an issue with the head gasket between 1&2
Or is this a piston ring nightmare.
#2 Ethel
  • 26,580 posts
Posted 23 June 2017 - 09:54 PM
Have you tried a drop of oil through the plug holes and rerunning the test? That's the usual tactic to further diagnose piston rings. Burnt oil with clean plugs could be exhaust valves & guides. A leak down test is the next step if you want to put off stripping it down.
Also take it you had all the plugs out during the tests?
