Hi everyone,
Just a couple of questions I hope someone maybe able to help me with. I have a couple of white speedo drive pinions whilst both have 17 teeth they are different to each other in that the square cable drive ends differ in size one being bigger than the other. Now one has come from a 1982 998 Mayfair (Larger of two) the other comes from a 1990 1275 Metro. So I am assuming that the smaller cable drive is Metro and the larger is Mini? please correct me if I’m wrong.
My second question and dilemma is I require an 18 tooth red pinion to go with my 7 tooth worm and can only find reference to the Metro item which I’m assuming has the smaller cable drive end which my speedo cable will not fit, and the item fitted to the SPi which has a larger diameter pinion gear that won’t work with the 7 tooth worm Have used ‘Guessworks’ calculator to come up with the 7/18 combination. Any help much appreciated. I hope the above makes some sense confusing myself a bit just reading it back.
Cheers.
