Swivel Hub Ball Joint Torque Settings
11 replies to this topic
#1 R1cbm
R1cbm
  • 81 posts
Posted 24 June 2017 - 01:16 PM
I'm investigating a noise from the front of the car - and realised that when I moved the wheel (holding top and bottom) there's play in the top ball joint on the passenger side (where the noise is coming from). So I thought I would check it was tight, and pack with grease.
It was not tight by a very long way - which explains the noise.  However, when I checked the Manuel, it states 75 lbft which seems high..... so I googled and found this : Swivel hub ball joint socket - 70 to 80(lbft)
So I have tightened it up, and thought I would check the other side. The nut on the drivers side was smaller (is this normal), and also is loose.  This made me question if I was over tightening them at all.  Photo's attached with red lines pointing to the nuts I am tightening.
#2 R1cbm
R1cbm
  • 81 posts
Posted 24 June 2017 - 01:25 PM
http://s679.photobuc.../Bolts.jpg.html
Edited by R1cbm, 24 June 2017 - 01:27 PM.
#3 Swift_General
Swift_General
  • 871 posts
The domed nuts are all the same size (1.5" AF) so I not sure what you're referring to as can't see any photos.
#4 R1cbm
R1cbm
  • 81 posts
Posted 24 June 2017 - 01:28 PM
I've provided a link - couldn't get the image to work.
You can see on the right the nut has been tightened up as you can see more thread at the top
Edited by R1cbm, 24 June 2017 - 01:31 PM.
#5 GraemeC
GraemeC
  • 7,451 posts
Posted 24 June 2017 - 01:37 PM
The 70-80lbft is for the ball joint domed nut which is 1.5" AF
I'm not sure of the torque for the ball joint pin nut that you point to - it may not be specified.  However these should be good and tight.
The difference you see in nut size (height) is because one is a plain nut (should have a heavy duty spring washer under it) and the other is a nyloc type nut.
#6 Swift_General
Swift_General
  • 871 posts
Posted 24 June 2017 - 01:39 PM
Ahh now I see. The nut indicated simply holds the taper into the top arm (I say simply but it is obviously very important and of concern it was loose). The nut on the passenger side looks right, drivers side doesn't (looks like possibly a nyloc nut?). Each nut has a split washer under it, or should have. Tightening this nut however will not change the slop in the ball joint itself. That is controlled by shims under the domed nut to which I referred. If you have torqued the indicated nuts to 75 lbft you have over torqued them (don't have a manual to hand but I'm guessing the figure is more like 40). I would be having the hubs off for a full inspection.
#7 R1cbm
R1cbm
  • 81 posts
Posted 24 June 2017 - 02:07 PM
Roger that, thanks I will inspect further
#8 RooBoonix
RooBoonix
  • 1,225 posts
Posted 24 June 2017 - 02:38 PM
For some reason 56nm pops to mind when mentioning the ball joint nuts which hold it in the taper... 40lbft as mentioned above wont be far off this.
#9 Spider
  • 15,236 posts
Posted 24 June 2017 - 08:45 PM
The factory torque setting for the Taper Pin (7/16" UNF) Nut is 35 to 40 ft / lb.
#10 Compdoc
Compdoc
  • 612 posts
Posted 24 June 2017 - 10:03 PM
Photobucket  have decided to not allow access to anyone using a browser with an ad blocker. So putting a link to their servers will only allow about 25% of members to view it.
I have decided to cancel my Photobucket account.
#11 tiger99
tiger99
  • 8,584 posts
Posted 25 June 2017 - 02:52 PM
You are certainly going to need a new ball joint. Please see the other on-going discussion, and follow the procedure in the Rover manual EXACTLY.
#12 R1cbm
R1cbm
  • 81 posts
Posted 26 June 2017 - 11:48 AM
Thanks - will do!
