Blown Head Gasket. Tappets?
8 replies to this topic
#1 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 24 June 2017 - 01:42 PM
I had my mini serviced a couple of weeks ago. It's a 998 with sw5. I asked for tappets to be set to 15 thou. After 30 or so miles the head gasket blew between cylinders 3 and 4 - the compression dropped to 20 on those pots. Suspecting possible valve issues I checked a tappet on cylinder 3 and 4. Both were 8 thou. I've whipped the head off and the gasket has blown (half inch of gasket gone) between 3 and 4.
Could the blow be a coincidence or linked to the over tight tappets?
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 24 June 2017 - 01:51 PM
I allway's found it was a coincidence when the head gasket went and messed with the engine-service that y I always do them my self.
besides you will never know or prove it .any chance you had would have been to take back as soon as it went wrong..
#3 Mrpeanut
Mrpeanut
  • 1,019 posts
Posted 24 June 2017 - 02:00 PM
Yeah, I know. It was sheer laziness on my part but now the head is off I'll fit my 295 head so no big deal. It's more an issue of whether there could be a link. I thought there could have been a burnt valve but don't think that's the case.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,066 posts
  • Name: Neil
Posted 24 June 2017 - 02:07 PM
One of those things that happens. Coincidental thats all.
#5 Mrpeanut
Mrpeanut
  • 1,019 posts
Posted 24 June 2017 - 05:57 PM
Cheers guys. I've only ever had blows in between 2 and 3 and had understood that a blow out wide usually points to an underlying problem. Is that not the case?
#6 carbon
carbon
  • 2,590 posts
Posted 24 June 2017 - 06:19 PM
Worth checking the block face is dead flat when the head is off.
#7 sonikk4
sonikk4
  • 16,066 posts
  • Name: Neil
Posted 24 June 2017 - 07:21 PM
It could have just been a poor gasket. I would run a straight edge over the face of the head and block just to check.
#8 racingbob
racingbob
  • 3,061 posts
Posted 25 June 2017 - 08:06 AM
What's the best head gasket for the 998 also what is the depth of a 295 head is it the same as 940 2.75
#9 Cooperman
  • 23,320 posts
Posted 25 June 2017 - 01:59 PM
The standard 295 head is 2.75" deep, but the chamber volume is 28cc on a 295 and 24cc on a 940 (nominal)
A 295 needs to be skimmed to the correct volume and it is best for a 998 to have flat top pistons with a 295 head.
