Wheel Speed / Abs Sensors
14 replies to this topic
#1 lsdweb
lsdweb
  • 65 posts
Posted 24 June 2017 - 10:06 PM
Hi All
I need to fit wheel speed / ABS sensors to my hillclimb Mini.
Before I embark on (for me) a major technical mission, were any of the road cars fitted with ABS / road speed sensors or has anybody fitted these to their Mini?
Wyn
#2 nicklouse
  • 18,998 posts
Posted 24 June 2017 - 10:11 PM
none fitted to the Mini.
Ok so now the question what are you actually fitting?
I have fitted wheel speed sensors to a "mini" before but it all depends on the application.
#3 Avtovaz
Avtovaz
  • 1,306 posts
Posted 24 June 2017 - 10:13 PM
is it for a trip meter???
#4 Spider
  • 15,684 posts
Try Trigger-Wheels.com for the wheels and possibly the pick-ups.
#5 lsdweb
lsdweb
  • 65 posts
Posted 24 June 2017 - 10:15 PM
For launch and traction control.
#6 Spider
  • 15,684 posts
Posted 24 June 2017 - 10:18 PM
http://trigger-wheel...en-uk/p155.html
#7 nicklouse
  • 18,998 posts
Posted 24 June 2017 - 10:23 PM
simple IIRC you only really need a single trigger on the a rear wheel.
think we just had a magnet attached to a drum.
#8 Avtovaz
Avtovaz
  • 1,306 posts
is that for all 4 wheels then?
interested as when i do finally get my project car, id like to hide abs on it ...
#9 Avtovaz
Avtovaz
  • 1,306 posts
Posted 24 June 2017 - 10:25 PM
for traction wont you need to know real car speed and driven wheel speed?
#10 nicklouse
  • 18,998 posts
Posted 24 June 2017 - 10:44 PM
nope. just engine speed and real ground speed (non driven wheel)
#11 lsdweb
lsdweb
  • 65 posts
Posted 25 June 2017 - 10:41 AM
Thanks for the replies everybody. I think the ECU (Emerald K6+) measures speed of driven and non driven wheels so all 4 will be best.
#12 nicklouse
  • 18,998 posts
Posted 25 June 2017 - 10:48 AM
it says up to.
does not mean you have to. good on a car that has ready to read abs sensors but a pain id you have nothing to start with.
manual read before spending money that is not needed.
#13 lsdweb
lsdweb
  • 65 posts
Posted 25 June 2017 - 03:23 PM
I'd have to measure at least three. One non driven and both driven wheels.
#14 nicklouse
  • 18,998 posts
Posted 25 June 2017 - 05:23 PM
why?
all you need is one non driven and the engine. or have people gone and made things more complex in the last 25 years.
#15 lsdweb
lsdweb
  • 65 posts
Posted 25 June 2017 - 06:27 PM
ECU measures speed of wheels and (depending on parameters) will cut fuel / ignition if one wheel is spinning faster than another. The non driven wheel is the one that the front is measured against if that makes sense.
