Med Vs Dsn Oil Filter Housing - Thread Issue?
20 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2017 - 02:17 PM
I am replacing my current MED (silver) housing with a DSN (black) with provision for a temp sensor.
The thread size on both housing for the oil drain line are 1/4NPT.
On the MED housing the taper seals up no problem:
3DAFAB73-CB48-4204-8B8B-B72BF016F37C_zps
However, in the DSN housing it never really seals on the threads and the union screws all the way in until the shoulder of the union fouls the housing (at least it seems like that).
84BAA7F1-A53B-49A9-BEDB-C1BC11905AAF_zps
Measuring the first threads the MED:
A10B8BE5-0401-4FB9-9114-BFDE97A8E6D6_zps
The DSN:
27050061-255C-4DE3-A467-664A244A6883_zps
While threading the union into the DSN housing it certainly feels a lot looser than it does with the MED housing.
I wonder if there is a problem? Or do I worry about nothing?
#2 AndyR
AndyR
  • 453 posts
  • Local Club: None
Posted 25 June 2017 - 03:02 PM
Seems as though the taper has been cut much deeper.  Have you checked that it is in fact a taper?
Andy
#3 sledgehammer
sledgehammer
  • 3,102 posts
Posted 25 June 2017 - 04:07 PM
would a dowty seal / washer work , or is the thread too loose ?
http://www.potterass...izing_chart.pdf
we use them at work at very high pressure
is there enough of a mating surface for one ?
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 25 June 2017 - 04:36 PM
If it's been cut correctly I'd just give it a few wraps of ptfe tape to build it up and when you've screwed it in trim if off. Having said that, I'd talk to Grant first just to make sure the thread has been tapped correctly and you're fitting the correct connector.
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2017 - 05:05 PM
Andy
Yip it is tapered.
#6 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2017 - 05:06 PM
The thread is too loose.
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
I give them a call tomorrow.
#8 nicklouse
  • 18,657 posts
Posted 25 June 2017 - 05:18 PM
if you bought the kit from MED (head and pipe) there is no guaranty that they put the same thread in the housing for the adaptor to the flex hose.
call both and check.
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2017 - 06:49 PM
Both are 1/4 NPT as stated on both webpages.
#10 nicklouse
  • 18,657 posts
Posted 25 June 2017 - 07:15 PM
well if you actually read the info they dont say that-
The thread in the filter head is 1/4" NPT so you will need a hose or adaptor to suit this.
It will not work with the factory fitted metal pipe.
The filter head has a ¼ NPT taper thread for oil pipe union fitting, this is the standard thread as used on the standard A series filter head.
the MED one does not say what the thread in the housing is just what the adaptor is top allow it to work with the standard pipe.
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 25 June 2017 - 07:25 PM
I must be missing something:
MED - The filter head has a ¼ NPT taper thread for oil pipe union fitting
DSN - The thread in the filter head is 1/4" NPT
#12 Spider
  • 15,038 posts
Posted 25 June 2017 - 08:09 PM
From that, the MED thread is a tapered thread and the DSN a parallel thread. They are different and not really interchangable.
#13 nicklouse
  • 18,657 posts
Posted 25 June 2017 - 10:18 PM
but NPT should be tapered - NPS is the straight thread form of NPT (and other variations).
again ask the suppliers what the actually supplied.
#14 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 26 June 2017 - 09:34 AM
having called both MED and DSN
Both the MED and the DSN housing are 1/4 NPT (tapered).
DSN assured me that the the issue I thought i was having is a non issue. I should use  some thread sealant-
#15 Midas Mk1
Midas Mk1
  • 5,786 posts
  • Local Club: S.U.N.M.C
Posted 26 June 2017 - 09:39 AM
I used ptfe tape on my DSN oil filter head / oil  temp sender connections, seemed to work.
