Veglia Borletti Gauge Wiring
2 replies to this topic
#1 AeroNotix
AeroNotix
  • 267 posts
Posted 26 June 2017 - 03:17 PM
Hi,
Looking for information on wiring up the dials into the dashboard in the attached images. They are Veglia Borletti dials on a 1990 carb 1.3 mini. This is not my mini. I am asking for a friend so this is unfortunately all the information I have.
They tell me that they swapped these dials from an innocenti mini and would like to put them into an English produced mini.
My questions:
* Do the innocenti/Veglia Borletti dials require different sensors to make them work, e.g. the fuel sender has different wiring/different resistance ranges?
* Is the wiring exactly the same? I can't imagine that these dials would require vastly different wiring from the typical stock/Smith's gauges.
Thanks in advance.
#2 mini13
mini13
  • 3,811 posts
Posted 26 June 2017 - 08:47 PM
Yes the Inno had different sensors,
http://www.minimania...perature_sender
the fuel gauge actually had a light! luxury! so had a different sender too.
apparently jaeger sensors may work
#3 InnoCOOPER
InnoCOOPER
  • 86 posts
Posted 15 July 2017 - 03:24 AM
I think you can use a normal temp sender and wire in a resistor to compensate.  The original sensors are very very rere. Try Ebay.it.
