Leaky Roof Ariel?
Posted 01 July 2017 - 07:08 PM
Posted 01 July 2017 - 07:28 PM
Posted 02 July 2017 - 06:56 AM
This is a clear silicone sealant used in plumbing and a little of this will fix nearly any leak!
Fernox LS-X Leak Sealer 50ml:-
http://www.screwfix....CFS0T0wodtq4JdQ
Edited by mab01uk, 02 July 2017 - 06:56 AM.
Posted 02 July 2017 - 03:18 PM
If the ariel is tight against the roof try some Captain Tolleys Creeping Crack Cure, works great on windscreens so should do what you need.
Posted 12 July 2017 - 09:04 AM
Its possibly just a perished gasket.
Mine is mounted to the rear of the roof, was taken off a Corsa B. I used an old innertube cut to shape and used that as a gasket. Hasn't leaked yet and has been on the car for about 12months....
You will need to drop the headlining to gain access to the base of the antenna...
Posted 13 July 2017 - 07:55 AM
Gasket was surprisingly very good. The Captain Tolleys stuff did the trick.
Posted 13 July 2017 - 09:19 AM
Wish I had shares in it
Remember to re-apply it every few months as it does eventually wash out
Edited by panky, 13 July 2017 - 09:21 AM.
