Drifting Out Roll Pin From Gear Change Rod
Posted 04 July 2017 - 02:48 PM
Sorry to repeat a post but I have read all tips from previous posts to try shift the stubborn little roll pin through the gear selector shaft. It won't budge- I've got the special punch from minispares...which I've hit hard enough to bend it!
I've soaked it in all sorts. The collar moves slightly so it's stuck in the gear selector shaft.
Am I missing something?
It's the pin closest to the diff I'm supposed to be removing isn't it?
I'm wanting the engine out of my clubman....I've only got this and a rusted engine tiebar to free and I can remove it.
Thanks in advance
Posted 04 July 2017 - 02:52 PM
Posted 04 July 2017 - 03:06 PM
I've had to leave it for today, so frustrating when something so small stalls progress!
Is the gear selector shaft steel? Is it likely to be rust that's fused it in?
The car was a barn find so I've come across a fair few rusted bolts & Clevis pins but they've always taken less work to free than this tiny pin!
For the amount of force I've hit it with compared to the surface area of the pin that's potentially rusted, it really should be out by now!
I'll put a pic up tomorrow if tonight's soak doesn't work.
Posted 04 July 2017 - 03:33 PM
Help!
Thanks in advance
For the really difficult pins I use the tool from this company https://minipreservation.co.uk/ it's the one halfway down on the right hand side. Works every time, just make sure you put it in reverse before you try.
Posted 04 July 2017 - 04:19 PM
Help!
Thanks in advanceFor the really difficult pins I use the tool from this company https://minipreservation.co.uk/ it's the one halfway down on the right hand side. Works every time, just make sure you put it in reverse before you try.
Those work great. A little expensive but definitely worth it on stuck pins
Posted 04 July 2017 - 04:28 PM
Posted 04 July 2017 - 05:12 PM
I might invest in one anyway, I've got to get the Clevis pin out of the clutch arm when the engines out....I presume that tool will make it loads easier!
Thanks for all the input....will update Tomorrow
Posted 04 July 2017 - 05:30 PM
That not a problem, you'll be able to level the roll pin with a pair of adjustable grips.Great stuff.....not sure it'll work as the pin is slightly to one side. I can move the collar the small amount of space it has each side though.
Posted 04 July 2017 - 06:09 PM
ve got both tools punch and big hammer and the g clamp type both work fine.
if the puch dont work use a bigger hammer its true bigger hamer works for me.
and as said by Northernpower "Those work great. A little expensive but definitely worth it on stuck pins "
Posted 05 July 2017 - 01:08 PM
Thanks for all your suggestions...now to get this engine out!
Posted 05 July 2017 - 01:57 PM
The pesky roll pin finally came loose! Seems the submerged soak worked...there was a few sweary seconds when the bent minispares punch got stuck in the hole after the roll pin dropped out but at last it's free!
Work can now resume
