Spec:
Mini 850 1976. No mods.
Mechancial fuel pump - chucking out fuel nicely
Vented tank (clear)
SU HS4 Carb
All new Bosch plugs (BOSCH WR7DC+), which are equivalent to the original Champion N9YC
Running on unleaded with valvemaster added.
New coolant, water pump and thermostat stat working fine. ALl flushed through recently - nice and clear.
Symptoms:
starts OK from cold (usually!)
once heated up, goes very smoothly for the most part, but intermittently tending to stutter and stall, even when rolling.
This is fixed by pulling out choke a little bit. This clears the stuttering and choke can be returned to hot position with very brisk running for 5-15 mins more.
When you stop, the engine will die spontaneously after a few mins, unless you tap the throttle pedal.
If it dies, or you turn it off, it will NOT restart.
Starter turns over fine (until battery flattens).
There is a spark at all the plug gaps (except the time i flooded it !)
Once it's cooled down a bit, it can usually be pursuaded to get going again and runs fine, for 15-20 mins more.
What I've checked:
I've used the piston lifting pin method to set the mixture to what i think is correct.
Timing, dwell , points, condenser, rotor arm, distributor cap: all good or renewed.
On examining plugs, they look sooty to me - smooth black carbon, but dry. No oil.
I noticed the plugs (all new, and with correct resistance on core, no earth faults) didn't smell of petrol last time i cleaned them stuck at the roadside (something to do while it returns to cold) - that despite winding the starter loads.
Suspecting fuel line / vapour lock, I risked detaching fuel feed to float chamber at carb end and wound starter - loads of pertol coming out.
Anxiously delved into carb (new territory for me): needle was a bit rough with deposits - polished gently with cloth, now smooth and gleaming.
Piston rises and falls freely.
Dash pot is clean and smooth and has clean SAE20 oil to required level.
Throttle butterfly opens and closes fully and has no significant play.
Breather tube from tank is free of blockages.
Choke is fully disengaged when in hot position and is set to catch throttle cam as per haynes manual.
air filter is new.
Today I risked removing eth fuel line where it goes into the float chamber when it refused to start again when hot. The engine had been off for a few minutes but the fuel came out of the end of the fuel hose under pressure (about 1 tablespoon full, over the back of a hot engine !!!)
So, I don't think it can be vapour lock (I'm going to change the original bare metal tube for an armoured neoprene fuel line just in case). - happy to be convinced otherwise iff the symptoms fit (positive pressure at fuel line into float chamber???)
The fuel pump seems to be delivering fuel to the float chamber.
But I'm not convinced fuel is getting through the carb to the cylinders.
The clues are: 1) misbehaves when hot, 2) positive pressure in fuel line to float chamber even when engine off.
It was running absolutely beautifully - about 13 yrs ago, before I SORN'd it.
It passed an MOT last week, including CO2 and HC values in the lower half of the range on emissions (I supsect the test was performed below normal operating temperature). The mechanic who got it through MOT said it was runnig " a bit rich", which surprised me in light of the emissions values.
I want to avoid going down the electric fuel pump route if possible - I feel sure there is a problem with the carb somewhere.
I've looked at vapouyr lock / fuel pump threads on here - nothing seems to quite fit the symptoms.
Where else should I look?
Happy to provide more details if needed.
Thanks in advance for any assistance.
Goat
