Faulty Volt Meter
Posted 11 July 2017 - 12:51 PM
It's a smiths gauge with a +ve feed coming from number 2 blade on the fuse box and another wire running to earth.
Any ideas would be appreciated
Andy
Posted 11 July 2017 - 01:03 PM
Posted 11 July 2017 - 01:11 PM
Posted 11 July 2017 - 01:24 PM
Set the multimeter to resistance (often there's an option which beeps when it detects zero resistance) and connect it to the terminals.
Posted 11 July 2017 - 01:49 PM
Posted 11 July 2017 - 02:19 PM
Posted 11 July 2017 - 02:44 PM
Posted 11 July 2017 - 11:57 PM
Put one probe on the + terminal of the smiths and the other on the body with the meter on Ohms the meter should read "0" indicating no circuit to earth. Check the smiths meter has the fibre washers under the terminals as this would cause a short if missing/split
Posted 12 July 2017 - 12:14 AM
An ideal (theoretical) voltmeter should have infinite resistance. On the other hand an ideal ammeter should have no resistance at all. Neither case happens in real life but it comes close.
