Hif 44 Needle Advice
11 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 11 July 2017 - 08:37 PM
I'm helping my mate recomission his Cox Gtm which is fitted with a 1330 a series engine with worked head and we think a 286 cam it came with a 40 dcoe fitted which is in a very poor state so we have decieded to fit a Hif 44 su to get it running and make it easier to set up at home before getting it on the rolling road. What needle/ spring would you advise as a starting point to get it running at a safe level?
Andy.
#2 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Posted 11 July 2017 - 08:47 PM
I had a 1293 with a 286 and worked head which ran perfectly with a BDL. I've also had a 1330 with and evo1 cam and very well flowed head which went well with a BDP. Someone with more knowledge than me will be able to give you a better steer but either of those may be a reasonable starting point.
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 11 July 2017 - 09:57 PM
As Mrpeanut says you may well be ok with BDL or BDP  they are both a usable needle for a tuned 1275cc plus...BDL is the standard MG metro BDP is generally stage one. BBC (nowt to do with telly or Blackburn brake and clutch haha) is a good one for a 286/296 cammed engine.
All three are very similar at the bottom end, BBC being leaner at the bottom and then much richer...its gunna be a guess anyway as its pretty much an unknown motor and I guess won't be run much or revved too high before the dyno.
By Bottom end I mean the thick end of the needle, bottom end of revs / throttle.
If you can get it started/running and revving a bit without drowning the plugs and ticking over reasonably (even if its high) then its dyno time
Hope this helps
#4 Dusky
Dusky
  • 5,322 posts
Posted 11 July 2017 - 10:42 PM
The jetting in the weber Will give away what needle would be good.
#5 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 22 May 2018 - 04:44 PM
hi yall
its been a while.
well i have caddy on the road.
goes like a rocket.
i am running a bdd needle in my hif44 on a 1330cc with 276 kent cam but its a bit juicy on fuel.
roller rockers 1.5 LDX, med pistons and pushrods, lightened and balanced flywheel with a turbo clutch plate.
the standard needle was a bfm, had it static tuned and a bdd was fitted which allowed her to run better.
idle is a little lumpy due to the cam and im running a k&n air filter.
too improve the fuel range i had a 10.5 gallon tank custom made and that's in the boot in-place of the standard tank.
is there another needle or needles i can try to reduce fuel consumption but still have the same acceleration.
any help would be good.
regards
rapidmini59
Edited by Rapidmini59, 22 May 2018 - 04:47 PM.
#6 racingbob
racingbob
  • 3,061 posts
Posted 22 May 2018 - 05:37 PM
you may need a bdk
#7 Inno
Inno
  • 138 posts
Posted 08 November 2018 - 05:46 PM
Hi there....I would like to avoid new topic so I will post my question here...
I have newly rebuilt Hif44 (all new parts) and I will use it with 1290 engine, fitted with Evo001 cam, K&N filter, 1.27 standard rockers assembly, LCB RC40, lighterflyweel, 35.7 intake valves, slightly bored head...
My question is what would be good hif 44 spring and needle as a starting position for this engine. I am hoping for 95HP.
Thanks in advance!
#8 whistler
whistler
  • 1,818 posts
Posted 08 November 2018 - 07:50 PM
Thanks in advance!
Think you're being a bit ambitious looking for 95bhp with that setup.
#9 Mrpeanut
Mrpeanut
  • 1,019 posts
Posted 08 November 2018 - 11:21 PM
Thanks in advance!
^^^^ see above.
#10 Inno
Inno
  • 138 posts
Posted 08 November 2018 - 11:30 PM
Thanks in advance!
I am sure you are right but what to add to gain at least 90?
#11 Dusky
Dusky
  • 5,322 posts
Posted 09 November 2018 - 07:45 AM
A better head and bigger cam. But if it's a roadcar just keep your spec and enjoy the torque.
#12 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 09 November 2018 - 02:07 PM
hi yall
its been a while.
goes like a rocket.
regards
rapidmini59
If you have not had it on a rolling road you are  guessing,  as is everyone else
...get it set up correctly you will have the best of both
After a RR session its at optimum efficiency... don't boot it and you get the optimum fuel use
A rolling road tune is a lot cheaper than fuel
