Electrical
2 replies to this topic
#1 splintercat
splintercat
  • 616 posts
Posted 13 July 2017 - 08:47 PM
having problems with my heater.  the blower aint working. it,s a two stage switch.          spade terminals are green with black wire         blue with black n blue wire           black with black n purple wire
3 pin toggle switch                        so i am pesuming that green spade with black wire is earth        so does that go on the middle terminal  and the other two any way round?????
this switch is the YUF101410 switch which is correct i think but cant find any wiring diagrams for it     even looked ar spi/mpi diagrams???
no luck in googling it or on yu tube
ps the fuse is good good but nothing on any of the leads.
Edited by splintercat, 13 July 2017 - 08:48 PM.
#2 Mike L
Mike L
  • 159 posts
Posted 13 July 2017 - 11:08 PM
Try here. Pick the one called Electrical Circuit Diagrams
http://www.renegadem...ical-documents/
Edited by Mike L, 13 July 2017 - 11:11 PM.
#3 splintercat
splintercat
  • 616 posts
Posted 14 July 2017 - 07:33 PM
cheers for that sorted basic two position toggle switch, earth the centre via the black wire greeen spade, then the other two wires are either directly from heater motor or from motor via a resistor this gives an extra load therefore slower speed, just put them on the correct terminals, thank you anyway.....
