Speedo 90 Degree Adaptor
10 replies to this topic
#1 NZMini1275
NZMini1275
  • 227 posts
Posted 15 July 2017 - 09:24 PM
Hi I have a center speedo and also Hif44 carb with Itg filter. The speedo cable has to bend quite sharply to fit. My newish cable has just snapped about where the bend is so I guess I need to rectify this. After searching here I found that you can get a 90 degree drive that fits into back of speedo.
I have emailed speedy cables as it looks like they may do one.
Does anyone have any other links to suppliers that have one that will fit
Dan
#2 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 15 July 2017 - 09:45 PM
I've got a standard long centr cable with my setup as above, shouldn't need an adaptor. Just make sure the hole in the centre plate is in the right place, we had to make a new plate as the original plate was recessed to where the itg was.
#3 NZMini1275
NZMini1275
  • 227 posts
Posted 17 July 2017 - 05:27 AM
I don't have a plate on mine. Only place for the cable to come out is at least half way up filter as on mine its tight back. This means the cable has to bend sharply.
I found a new old stock smiths adaptor on ebay for cheap so all good.
Edited by NZMini1275, 17 July 2017 - 05:28 AM.
#4 Cooperman
  • 23,326 posts
Posted 17 July 2017 - 07:21 PM
I use a 90 deg adapter as fitted to a Mk.2 Jaguar.
#5 Ethel
  • 26,074 posts
Posted 17 July 2017 - 09:20 PM
There was a Triumph used one too. Incredibly expensive if you have to buy new worth considering going electronic instead.
#6 NZMini1275
NZMini1275
  • 227 posts
Posted 17 July 2017 - 10:58 PM
Managed to get a new old stock smiths adaptor off eBay USA for a good price 👍
#7 mini13
mini13
  • 3,811 posts
Posted 18 July 2017 - 09:24 AM
I think my one was from a land rover
#8 whistler
whistler
  • 1,818 posts
Posted 18 July 2017 - 09:44 AM
Be aware that some 90 deg angle drives were also used as gear ratio adapters and were not necessarily 1:1.
#9 MrJenkinsEsq
MrJenkinsEsq
  • 38 posts
Posted 19 July 2017 - 12:43 PM
Does anyone have the part numbers of any of these that would be suitable for a Mini?  I have a Mk1 with the ITG filter, and it really is a tight bend to get the cable around it.  There seem to be quite a few on ebay when I search for speedo angle drive, but no mention of which ones are 1:1 ratio.  Although if I use a different ratio, it'll make my Mini faster, right?  :teehee:
#10 NZMini1275
NZMini1275
  • 227 posts
Posted 19 July 2017 - 06:28 PM
http://m.ebay.com/it...ed032%7Ciid%3A1
Edited by NZMini1275, 19 July 2017 - 06:33 PM.
#11 MrJenkinsEsq
MrJenkinsEsq
  • 38 posts
Posted 21 July 2017 - 08:37 AM
