Chrome Rear Roll Cage Hoop
6 replies to this topic
#1 paulk 7364
paulk 7364
  • 206 posts
Posted 16 July 2017 - 02:56 PM
As above can you chrome plate a standard roll cage?
#2 Tupers
Tupers
  • 4,173 posts
Posted 16 July 2017 - 03:45 PM
I theory yes but finding a company that would actually want to do it might be tricky.
That plating process wouldn't be any different from a big American bumper but the polishing would be an arse of a job.
#3 paulk 7364
paulk 7364
  • 206 posts
Posted 16 July 2017 - 05:31 PM
Ah yes I understand
I have heard about chrome look powder coating ?
Have you heard of this ?
Would that be cheaper?
#4 Cooperman
  • 23,513 posts
Posted 16 July 2017 - 06:10 PM
Because a roll cage/hoop needs to be padded for safety, there would seem to be little point in anything other than painting it. If you don't fit padding then a crash-helmet, at very least, should be worn when driving the car, but even then proper padding with the correct material is really important.
#5 paulk 7364
paulk 7364
  • 206 posts
Posted 16 July 2017 - 07:16 PM
It's only a rear cage. But I didn't take the safety aspect into
Consideration though
#6 paulk 7364
paulk 7364
  • 206 posts
Posted 16 July 2017 - 07:17 PM
#7 Cooperman
  • 23,513 posts
Posted 16 July 2017 - 08:21 PM
Your head will be very close to the tube which goes up just behind the seat side and across the top. Presumably you are wanting a roll-cage because you are concerned about what happens if you crash. In which case be even more worried about what happens when your un-protected head hits the un-padded tube.
Also near-in-mind that with a roll-cage it is really necessary to use full harness belts which then makes your Mini a 2-seater. Anyway, it is virtually impossible to get a rear seat passenger in among the tubes.
A better answer is to drive a classic car gently, in relative terms, and simply enjoy the 1960's retro driving experience  :D .
