Have just taken the head of my 1275, replaced a valve top cap and changed from 1.5:1 roller tip rockers back to standard and now it won't start. It cranks over ok for a few turns then slows down almost to a stop before then putting out a big puff from the carb (HIF44) breather. I've had the head on and off loads of time in the past and can't think of anything I've done differently this time. I've double checked the tappets and none of the timing or electrics have been touched. It's almost like it's not exhausting the gas down the normal exhaust route so that pressure builds up so much that it forces it way back out the carb breather. Any ideas?? I'm stumped.
Posted 17 July 2017 - 07:58 PM
Posted 17 July 2017 - 08:02 PM
Posted 17 July 2017 - 08:06 PM
Yep, I'm pretty certain (might just go check again though!), always take a photo and they match up. Plug gaps haven't been touched so should be fine.
Posted 17 July 2017 - 08:16 PM
If you've had the plugs out there's a chance you may have dropped one on the tip and or somehow closed the electrode up. If you left them in the head you may have caught them with the spring compressor. For what time it takes it may be worth checking.Yep, I'm pretty certain (might just go check again though!), always take a photo and they match up. Plug gaps haven't been touched so should be fine.
Posted 17 July 2017 - 08:20 PM
True, I'll whip them out and get the feeler gauge on them. Fingers crossed. Thanks.
Posted 17 July 2017 - 08:51 PM
Plug gaps all at 0.8mm, leads on correct order 1-3-4-2. Same scenario. I feel like it must be something obvious but I've no idea what!
Posted 17 July 2017 - 08:58 PM
You sure the fuel line is on the inlet and not the float chamber vent.
Edited by panky, 17 July 2017 - 08:58 PM.
Posted 17 July 2017 - 09:01 PM
Fuel line goes in at the lowest inlet. Breather goes in at the upper and most forward one and the overflow is in between.
Posted 18 July 2017 - 05:02 PM
And it does have fuel, just checked that after having a sudden panic
Mini Technical Sections →
Problems, Questions and Technical →
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
