When Did The Clubman Change To Rubber Mounted Front Subframe?
10 replies to this topic
#1 Simon30974
Simon30974
    Starting My Mini Up
  • 2 posts
Posted 22 July 2017 - 05:48 AM
Hi,
Does anyone know when in 1976 the Clubman changed from solid to rubber mounted front subframe? Do you have a 1976 registered clubman? Is it solid mounted or rubber?
Simon
#2 mab01uk
mab01uk
  • 12,538 posts
Posted 22 July 2017 - 06:48 AM
Chris Rees book 'The Complete Mini' says for Clubman it was May 1976.
Mini Clubman - May 1976:-
New  subframe mounts fitted (Chassis Number XC2S2 341660 - Saloon, and XL2W2 330503 - Estate)
Also fitted new black grille, twin column stalks, new rocker switches, larger pedals from Allegro, moulded carpets, ignition lock from BL Princess, softer springs and damper settings (saloon only).
Edited by mab01uk, 22 July 2017 - 06:53 AM.
#3 Simon30974
Simon30974
    Starting My Mini Up
  • 2 posts
Posted 22 July 2017 - 07:20 AM
Thank you mab01uk
So his book says for the saloon, chassis number 341660 onwards was rubber mounted?
That's great info thank you
Might just be adding Chris Rees book to my Christmas List!
Simon
#4 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 22 July 2017 - 03:24 PM
Don't forget though that British Leyland would have used up the old parts first so there are always exceptions that slipped through.
#5 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 22 July 2017 - 08:50 PM
Reading this made me check something I had been meaning to do!
My Clubman which was first registered 07/01/78 vin no XC2S2-293****
has a solid, twin bolt subframe, twin stalks, and early type ign-lock,
It seems to point to the coach builders having had it for a couple of years!
before it was registered
I have the Chris Reeves book just never got round to checking.
#6 richmondclassicsnorthwales
  • 942 posts
Posted 01 August 2017 - 10:02 AM
I also saw the above on an imported Mini, twin bolt subby on a registered 78 model !
Pretty sure it was a radical change as when they changed the subbys, they also changed from rubber couplings on the driveshafts to inboard CV joints, and additionally putting the pear drop mount on the front of the front subframe
#7 Spider
  • 15,142 posts
Posted 01 August 2017 - 10:09 AM
For what it's worth we had twin bolt solid mounted subframes to the end of production in December 1981.
#8 Ethel
  • 26,074 posts
Posted 01 August 2017 - 11:05 AM
Pot joints were being used before the subby changes. I reckon it'll be an accurate change point as they're major components that can't be interchanged. The pedals and lock may look like other models, but they won't be the same. I'm also dubious about the softer suspension claims.
#9 Rorf
Rorf
  • 866 posts
Posted 01 August 2017 - 11:59 AM
Here in South Africa the standard Clubman 1275s which were built until the end of 83 had the twin bolt subby, inner pot joints and A plus gearboxes but retained the pre verto clutch. Also had front drum brakes ha ha :proud:
#10 richmondclassicsnorthwales
  • 942 posts
Posted 01 August 2017 - 06:16 PM
I,m wondering who introduced "Mix And Match" first, was it the High Street or British Leyland !
Some good mixes out there !
#11 Spider
  • 15,142 posts
Posted 01 August 2017 - 09:15 PM
I did think that was the case in SA.
Our early 1275 Mokes also were fitted with Drum Brakes.
IIRC the Verto Clutch came was introduced in the UK around 1982 but we never got them here as our production finished in 1981 (1978 for Minis).
Rod shift came in 1974 and followed about 2 months latter with Pot Joints on most models,except the Moke that 'hung on to' the steel Hardie Spicer type joints for nearly a year longer, though the change over wasn't immediate.
