Magnum Door Skins
6 replies to this topic
#1 Avtovaz
Avtovaz
  • 1,267 posts
Posted 23 July 2017 - 09:37 AM
are they any good? I know the heritage ones will be the best but thought id ask about teh magnum ones first.
thanks
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 23 July 2017 - 09:41 AM
They will fit, I use them on doors they I repair to sell on.
Just check at the top of the skin as a few of them bow out. This can be dealt with but needs to be done before fitting. Also remove all of the rubbish primer coating they use.
#3 Avtovaz
Avtovaz
  • 1,267 posts
Posted 23 July 2017 - 09:46 AM
ill be looking at magnum stuff as i can get them from G&S classic escorts in widnes. I know the owner and would rather get stuff from him.
Do they do a repair part for the bottom of the door frame?
#4 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 23 July 2017 - 09:51 AM
Yes, right at the bottoms, they are not the best and will take some fettling to get a good fit and you will need to add metal to finish the bottom lip. Trim off any excess where it fits up the door carcass. If it's not needed there then pointless to use it all. Don't forget to add three drain holes right in the radius of the return where it fits against the door skin.
#5 Avtovaz
Avtovaz
  • 1,267 posts
Posted 23 July 2017 - 09:57 AM
right ok thanks, ill order a skin, but ill probably make the bottom part then, its only a bit of angle really, thanks!
#6 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 23 July 2017 - 10:17 AM
There is a curve to it so bare that in mind.
#7 Avtovaz
Avtovaz
  • 1,267 posts
Posted 23 July 2017 - 10:34 AM
right ok thanks, ive ordered the door skins just now, they will be here in the week, so ill get a door off the car and get it started! thanks
