Underseal Yay Or Nay?
Posted 24 July 2017 - 02:12 PM
Both options have their pros and cons, on the plus side it helps protect the bottom of the car from certain damage. On the minus side it hides a few sins as well- rust/ appalling welding and so on.
So...what do you think of it?
Posted 24 July 2017 - 03:28 PM
Posted 24 July 2017 - 04:24 PM
my current mini was and is plastered with under seal and im in the process of cleaning it off.
all i can say is, where it has stayed undamaged it has protected the car very well, but where it has let the water through ( rear valence closing panels) its a bloody mess !!!
Posted 24 July 2017 - 05:03 PM
Posted 24 July 2017 - 07:13 PM
Posted 25 July 2017 - 09:46 AM
What is the best method of removing old underseal?
Wire brush, scraper, sanding?
Using a drill, grinder, by hand, compressed air tools?
It's the next job unfortunately
Posted 25 July 2017 - 12:40 PM
Posted 01 August 2017 - 03:49 PM
Sad to say, underseal was a short term bodger's remedy, like oversills, but it is still sold and most people including many garage mechanics have no appreciation of the long term harm it always causes.
It is best to rely on a full paint process, starting ideally with zinc, or more likely an etch primer, followed by an epoxy primer, before applying stonechip. I fear that stonechip on its own may turn out to be as bad as underseal, as is powder coat once it is damaged. But you don't need a high build primer and lots of flatting under stone chip. Doubtless some real fanatic somewhere would....
Please wear a disposable hat and face protection as you are going to get very mucky. Sadly there is no fun to be had in removing underseal.
Posted 01 August 2017 - 04:18 PM
If the car was Ziebarted from new like mine was then there is every chance rust will have worked its way in (its never guaranteed for life.) Mine scraped off as it was hard then washed over with celly thinners.
My clubby once cleaned off and repairs done, everything was sprayed in Epoxy primer, then followed by 3 coats of stone chip. Not heavy coats though. Then it will be topcoated.
Posted 01 August 2017 - 04:47 PM
Posted 14 August 2017 - 07:48 AM
Thanks for the replies.
No one is selling this job to me but it has to be done .
I'm just waiting for my father-in-law to empty his garage so I can get her over the pit (Which hasn't been used for countless yeas apparently so that will be fun in itself)
Posted 14 August 2017 - 08:33 AM
No one is selling this job to me but it has to be done.
Just watch out for the massive hairy spiders that will grab you by the throat and try and suck the life out of you lol!
Posted 14 August 2017 - 11:55 AM
awful thing to call a mother in law!
Posted 14 August 2017 - 03:06 PM
Just watch out for the massive hairy spiders that will grab you by the throat and try and suck the life out of you lol!Thanks for the replies.
Hahahaha! That really made me laugh out loud lol 😂
Posted 14 August 2017 - 05:15 PM
Underseal products are not the problem. The problem is that most folks think one application will last 5 years.
It needs to be cleaned off and re-applied very regularly, most likely twice to three times a year.
Even when driving only in the dry, underseal will be eroded from the base of the inner wings and sill fronts due to dry road dirt from the roadwheels.
Regular inspection and re-application is the key.
