Diagnostic And Key Fob Programming
2 replies to this topic
#1 FlyingScot
FlyingScot
  • 2,664 posts
Posted 28 July 2017 - 07:59 PM
Sykes Pickavant ACR 4 with MAP pod and leads for SPi and MPi minis. Can read and clear MEMS ECU Error codes plus give live component readings and set the stepper. Can also read and clear airbag faults on the MPI cars and programme additional key fobs for the 5AS alarm/immobiliser system.
I am including the special lead (not developed by Sykes Pickavant) that allows programming of additional key fobs on the SPi (using the green connector). You can't buy this I developed it from first principles of my knowledge of the system.
I will include an additional checked and case refurbished keyfob suitable for adding to your MPi or SPi car with new battery.
You can't buy this on eBay nor can you use any of the newly developed MEMS readers to do what this this can do. Tested fully working comprising ACR 4 handset, SPi lead, ISO lead for MPI, MAP pod with software to do all of the above. Lead to use with SPi alarm system. Checked and refurbished key fob with new battery which can be programmed by the kit (at your risk) to your car giving a much needed spare.
Cost includes Royal Mail Special Delivery (insured) to U.K. mainland addresses.
Location Inverclyde (you can collect if nearby and I'll deduct an amount for postage and packing)
£295 payment by PayPal
If you want to match immobiliser and ECU this needs a different software option (iKEYS) which is possible at additional cost.
If you want shipping outside the U.K. you will have to contact me for a price
I have a couple of units which I have put together to reduce my "stock" of diagnostic systems (i.e. The wife is sick of all the mini "junk" I have)
FS
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 28 July 2017 - 08:01 PM
I'll add pictures once I get a method to host them, but most folks know what a ACR4 looks like and the leads I guess
FS
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 08 August 2017 - 10:18 AM
Bump
