Belts For Japanese Made Mini
Posted 29 July 2017 - 07:33 PM
But I have what appears to be a 1991 1275cc Japanese made mini with a AC unit that is carbureted.. I need to replace my Belts for the a.c. Alternator and I am trying to figure out which product to use.
Any help would be appreciated.
Cheers Kevin
Posted 29 July 2017 - 07:58 PM
I remember seeing this post - hope it helps
http://www.theminifo...lt#entry3484447
Also welcome to forum
Edited by phillrulz, 29 July 2017 - 07:58 PM.
Posted 29 July 2017 - 08:19 PM
Japanese made? I think not unless it's a Honda............................................
Posted 30 July 2017 - 03:52 AM
This is what you are after..
https://www.minispar...|Back to search
..or speak with David as mentioned in the other link. I got an A/C blower assembly from him a while back.
Edited by buznout, 30 July 2017 - 04:06 AM.
Posted 30 July 2017 - 08:53 AM
Posted 30 July 2017 - 10:38 AM
Maybe look at the Gates catalogue if nothing comes up on the mini specialist parts websites?
Belts are of a standard length in any car - so if you can workout what the belt size is it's easy to just get another one from an automotive supplier.
Part numbers are normally something like xxxyyy ...where the xxx = the belt type / shape and the yyy = length in MM.
I had the same problem with my 16V conversion, as moving the alternator shorted the belt ... I just measured the length and crossed referenced. You might even find it's used on another common fitment ..makes it even easier to order.
Edited by DomCr250, 30 July 2017 - 10:41 AM.
