Which Head Gasket. Help
10 replies to this topic
#1 richw911
richw911
  • 2,084 posts
Posted 31 July 2017 - 11:41 AM
Hello I've got a suspected head gasket issue.
My question is which head gasket is best to buy? And where from? Is there an uprated one which is best?
Fairly standard carbed 1275 63hp.
Any help or advice very much appreciated :)
#2 mini13
mini13
  • 3,811 posts
Posted 31 July 2017 - 12:10 PM
bk450
#3 slidehammer
slidehammer
  • 1,202 posts
  • Local Club: LSMOC
Posted 31 July 2017 - 12:22 PM
You might be better getting a complete head gasket set, as you will be disturbing the rocker cover and inlet/exhaust manifolds whist removing the head. Also I believe the below has superseded the bk450 Mini 13 recommended.
GUG702560HG (Mini Spare part no.)
#4 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 31 July 2017 - 01:41 PM
The AF470 which slidehammer metioned above has a black sealing ring for the oil feed.
The BK450 is recommended for performance engines and 8 port alloy heads where you should not have the rocker feed sealing ring which can cause problems.
For me it's the BK450.
#5 ukcooper
ukcooper
  • 1,625 posts
Posted 31 July 2017 - 01:52 PM
and don't over torque it..
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
Posted 31 July 2017 - 01:55 PM
This is worth reading http://www.calverst....asket-problems/ if you're not too familiar with the vagaries of the A series head gaskets and studs.
#7 richw911
richw911
  • 2,084 posts
Posted 31 July 2017 - 02:02 PM
Thank's guys! Who knew you could have so many choices and things to think about just for a head gasket!
#8 Cooperman
  • 23,513 posts
Posted 31 July 2017 - 03:59 PM
BK450 is the one you need.
#9 richw911
richw911
  • 2,084 posts
Posted 31 July 2017 - 05:43 PM
Many thanks for the help guys! BK450 it is then!
#10 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 01 August 2017 - 09:07 PM
I use the bk450 on my supercharged racer, 17 psi 167hp at the wheels, touch wood had no issues.
When the engine was first built buy a uk self proclaimed race engine expert he insisted on one of the
STEEL SHIM HEAD GASKET 3 layer.
at a cost of £90
 when this engine unit went pop due to a poorly manufactured gearbox, on the strip down I found the gasket had failed on 2 layers.
hard to believe as it then was only producing 8.8psi and c/r was poorly calculated at 7.8 I seem to recall.
factory items are hard to beat.
#11 richw911
richw911
  • 2,084 posts
Posted 01 August 2017 - 09:22 PM
Ah interesting! Thank you!
