Which Head Gasket. Help
Posted 31 July 2017 - 11:41 AM
My question is which head gasket is best to buy? And where from? Is there an uprated one which is best?
Fairly standard carbed 1275 63hp.
Any help or advice very much appreciated :)
Posted 31 July 2017 - 12:10 PM
bk450
Posted 31 July 2017 - 12:22 PM
GUG702560HG (Mini Spare part no.)
Posted 31 July 2017 - 01:41 PM
The AF470 which slidehammer metioned above has a black sealing ring for the oil feed.
The BK450 is recommended for performance engines and 8 port alloy heads where you should not have the rocker feed sealing ring which can cause problems.
For me it's the BK450.
Posted 31 July 2017 - 01:52 PM
and don't over torque it..
Posted 31 July 2017 - 01:55 PM
This is worth reading http://www.calverst....asket-problems/ if you're not too familiar with the vagaries of the A series head gaskets and studs.
Posted 31 July 2017 - 02:02 PM
Posted 31 July 2017 - 03:59 PM
BK450 is the one you need.
Posted 31 July 2017 - 05:43 PM
Posted 01 August 2017 - 09:07 PM
I use the bk450 on my supercharged racer, 17 psi 167hp at the wheels, touch wood had no issues.
When the engine was first built buy a uk self proclaimed race engine expert he insisted on one of the
STEEL SHIM HEAD GASKET 3 layer.at a cost of £90
when this engine unit went pop due to a poorly manufactured gearbox, on the strip down I found the gasket had failed on 2 layers.
hard to believe as it then was only producing 8.8psi and c/r was poorly calculated at 7.8 I seem to recall.
factory items are hard to beat.
Posted 01 August 2017 - 09:22 PM
