Rod Change Conversion Bracket
Posted 31 July 2017 - 06:37 PM
currently trying to fit my new exhaust to the pup but having trouble with clearance past the rod shift mechanic.
noticed the original mounting bracket has been used even tho it's a early floor that originally had the magic wand type of shifter.
have located a image of said bracket online but can't find a supplier?
tia
Posted 31 July 2017 - 09:17 PM
All our Aust made Minis had such a bracket factory fitted;-
Posted 31 July 2017 - 10:31 PM
Posted 31 July 2017 - 11:49 PM
yes GraemeC , that's the one I've found but it's from America, surely they are available in the UK?
we just make things fit. almost a straight bolt up to the cross member.
i made a bracket to go the other way, not too hard.
Posted 01 August 2017 - 08:20 AM
Moke Spider without going to far off topic, is that a rubber gaiter on the front of the rod housing to prevent dirt/water ingress?
Posted 01 August 2017 - 08:38 AM
Water and Dirt. It is a standard rubber that was fitted to all our Rod Shifts on both Minis and Mokes.
Posted 01 August 2017 - 08:49 AM
Some pics
I think they have been discussed on the forum before.
Posted 01 August 2017 - 12:38 PM
Moke, is that gaitor on the selector rod standard? I can't seem to find it on minispares nor the parts selectors.
